Hi guys,
so I’ve gond and bought a heap of Qubino remotes to remote control some of my switches that are in location where I cannot use a cable from the switch. Using I1 works like a charm. I1 is meant to be a physical dimmer and works like a monostable normally off (?) switch. However, I want to use I2 and I3, which are virtual circuits, to control other loads and these are bistable. Turning them on triggers a motion detector (that’s what they call it) and turning it off disables the motion detection. If I turn the light on or off from another location or a scene, the wall switch is now in the wrong position. I’ve emailed Qubino to ask if it’s possible to set I2 and I3 to be monostable, but apparently not…
So…is there a built-in function or a plugin I can use to “flip a bit” whenever the switch is turned on? For some switches I want to switch a load to the opposite but I also want to use one scene for one click and then another for the next click.
Any good ideas would be greatly appreciated! I know it’s not really a problem compared to other countries in the world - but it’s getting closer to the top of my list ![]()
Cheers ![]()
