I started playing with UI7 on a new Vera Edge. The good news is, all my other plugins and small number of test devices is working week. The bad news, PLEG is the only plugin not working reliably…and I depend on Richard’s powerful plugin to make my home run.
The issues I have personally with UI7 (and we should start keeping a list):
UI7#1 Triggers, Conditions, and Actions save only about 5% of time.
The “fix” is to wait one minute before reloading LUUP. Richard has attributed this to a Vera UI7 bug. I still can’t get it to save reliably in any browser
Perhaps offline editor may be desirable if the product won’t run correctly in the Vera UI long term.
UI7#2 I get a ‘Startup LUA Failed’ for after about an hour of configuring it. Only fix is deleting PLEG and re-installing it (losing all changes).
Documented more here: http://forum.micasaverde.com/index.php/topic,12759.msg224184.html#msg224184
This has happened using Firefox and Chrome more than 5 times doing simple configurations on a test system.
Latest test on new device:
- Firefox (latest)
- Created 8 Triggers (scene controller activate and deactivate)
- Waited 2 minutes on the page
- Reloaded Vera and then after it said “please wait” Refreshed Firefox
It gave Startup LUA error after first reload completed.
Log:
50 03/07/15 21:12:52.082 luup_log:128: PLEG-128:Initialize:Restart <0x777a6520>
01 03/07/15 21:12:52.086 LuaInterface::CallFunction_Startup-1 device 128 function Initialize failed [string "module("L_Progra>
01 03/07/15 21:12:52.087 LuImplementation::StartLua running startup code for 128 I_ProgramLogicEG.xml failed <0x777a6520>
Status report and log don’t work (due to Startup LUA error).
This is a showstopper bug that breaks PLEG.
Long term, once UI7 support allows PLEG (which I depend on) to run stable…and I know it’s not Richard’s doing for the changes Vera has made (though I do expect the product to function eventually)…I look forward to UI7 (and new Z-Wave + chip) based on my early experiences.
Any other issues (or fixes) to UI7 that is preventing you from using it?
