Program Logic Event Generator[14] : Startup Lua Failed
seeing this error all of a sudden… haven’t worked with vera in a while.
UI5
PLEG version 7.25
Can you send me the log file during a Vera Restart.
I have a fix to release this weekend … I would like to find/fix the problem.
I’m traveling but will try my best… thanks for your kind attention to this.
[quote=“RichardTSchaefer, post:2, topic:183990”]Can you send me the log file during a Vera Restart.
I have a fix to release this weekend … I would like to find/fix the problem.[/quote]
I have this on reset:
Please post or email the contents of the “ActionMap” variable using the Advanced tab for the PLEG device in question as well as a report.
Then clear the contents and save/reload Vera.
I will need to bullet proof this part of the code … but would be interested to see what was corrupted so I can find out why.
This field holds the delayed actions that have been initiated but have not run yet because of delays in actions.
Richard,
I have ActionsMap:
{PhoneyTV_ON= {Start ='1415359656', Next = 2},}
I did recently add that schedule…
PLEG report attached.
Thanks for all the help
Richard,
I just deleted the schedule, the conditions and the actions and the error went away. Thanks for pointing me to the issue!
Jim
Actually just deleting the ActionMap value in the advanced editor should have solved the problem.
I am guessing that at one time you had a delayed action for the the PhoneyTV_ON condition.
And that you deleted the delayed action while it was already triggered … and sleepiing … waiting to run the delayed action that was deleted.
got it, thanks again
