Products Benext
I am looked no experience of “Vera” with device Benext (European manufacturer), Therefore, I wonder if Vera or Veralite be detected and properly operate these products.
It will be necessary to develop new luup plugin (apps)?, Or simply the standard for PIR luup, lights, sirens, door sensors, etc…
The manufacturer may orient Vera about it, if I can buy these products from BENEXT and that they work properly. On their website you can find technical information about their products.
From already thank you for your information.
Likely most of their products (zwave devices), are just re-branded or OEM based devices that should work OK anyway.
If you are interested in Vera, then you’d be better trying to get a response from other users in your location as to the type of devices they are using on the open market.
