problems with products from gr-smarthome
I’ve the Vera plus controller and i bought some devices from company in china called gr-smarthome.
i bought PIR,DOOR,SIREN,AC,AV sensors and more
from all of the products only the siren is working, all other devices get identified by the Vera controller but not function at all.
the door sensor - if i take the magnet off it is not showing anything for ON or OFF, the same goes to the PIR etc…
what i’m doing wrong here?
http://www.gr-smarthome.com/en/
thx
Hi there,
These devices are not yet integrated into Vera but with a little bit of tinkering, there is a chance they might work.
Please log a ticket with our support team, to see if they can do something about this.(see my signature)
ok…
if i go into the advanced setting for the PIR sensor i see in the device_file D_GenericIO1.xml and in the device_json D_GenericIO1.json
what parameters needs to be in the advanced so the device will work correctly?
where i can find a documentation for all of this advanced setup parameters?
THX
