I have read several threads on the HM-TS001 but none recently. I just received one and it is recognized but I get “Waiting for wakeup to configure”. I set the wake up time interval to 10 sec. and still no change to the message. I can see the readings in the advanced tab but it seems I can do nothing with them. Has micasaverde fixed this issue (per threads dating back to last of 09 and first of 10) or are we still waiting, or am I doing something wrong?
It will most likely configure itself when it wants to and sometimes these battery devices take a while…
Even once it does it will probably need a bit of manipulation to get it to show up as the right of device rather than a genericIO device as I just went through this myself.
What version of UI4 are you running?
1.1.1008, unfortunately I am leaving town right now and will not be able to respond to this forum for a week.
Shock, how will you cope without the internet?
When you do get back (and if its configured itself now) then try the below which was something @wserverino helped getting mine to work.
Change the device type and device file to get it working by replacing the ones in the advanced tab for the parent and child devices respectively then save.
Parent = urn:schemas-micasaverde-com:device:ComboDevice:1 with a device file of D_ComboDevice1.xml
Child Temp = urn:schemas-micasaverde-com:device:TemperatureSensor:1 with a device file of D_TemperatureSensor1.xml
Child Humidity = urn:schemas-micasaverde-com:device:HumiditySensor:1 with a device file of D_HumiditySensor1.xml
