I have a few problems in the vera’s log
What does this mean pls?
TY.
ZWaveNode::AddPollingCommand light/switch node 3 doesn't support any COMMAND_CLASS_BASIC <0x2c3b3680>
02 10/19/12 13:08:01.106 ZWaveNode::AddPollingCommand light/switch node 3 doesn't support any COMMAND_CLASS_BASIC <0x2c3b3680>
02 10/19/12 13:08:01.107 ZW_Send_Data node 3 NO ROUTE (nil) <0x2c3b3680>
02 10/19/12 13:08:04.371 ZWaveSerial::GetFrame 0x2c3b2f60 timed out now 0 m_listGetFramePending 0 <0x2c3b3680>
02 10/19/12 13:08:04.371 ZWaveJobHandler::SendDataAbort got m_iFrameID 0 <0x2c3b3680>
01 10/19/12 13:08:04.372 ZWJob_PollNode::Run job job#5827 :pollnode #3 (0x1390568) N:3 P:100 S:1 ZW_Send_Data to node 3 failed 1 req 0x124cad0/1 abort m_iFrameID 0 <0x2c3b3680>
02 10/19/12 13:08:04.372 ZWJob_PollNode::PollFailed job job#5827 :pollnode #3 (0x1390568) N:3 P:100 S:1 node 3 battery 0 <0x2c3b3680>
06 10/19/12 13:08:04.373 Device_Variable::m_szValue_set device: 1 service: urn:micasaverde-com:serviceId:ZWaveNetwork1 variable: LastError was: Poll failed now: Poll failed #hooks: 0 upnp: 0 v:0xf97f30/NONE duplicate:1 <0x2c3b3680>
04 10/19/12 13:08:04.374 <0x2c3b3680>
02 10/19/12 13:08:04.375 JobHandler::PurgeCompletedJobs purge job#5827 :pollnode #3 (0x1390568) N:3 P:100 S:2 pollnode #3 3 cmds status 2
