Problems getting light level from hsm100
Could anyone tell me if there is something wrong with this code:
local lul_light_level = luup.variable_get (“urn:micasaverde-com:serviceId:LightSensor1”,“CurrentLevel”,38)
38 is the device number for the light sensor device
When I save this code in a scene I get a message in the ui “message box”: “error in lua for scenes and events”
Thanks in advance.
This code is correct. But is this all the code?
No. Let me get all the script. Thanks
Script follows. Thanks
local deviceNo = 28
local period = 5
local SS_SID = “urn:micasaverde-com:serviceId:SecuritySensor1”
local lastTrip = luup.variable_get (SS_SID, “LastTrip”, deviceNo) or os.time()
lastTrip = tonumber (lastTrip)
if ( tonumber (lul_light_level) < 15 ) and ((os.difftime (os.time(), lastTrip) / 60) >= period) then
return true
else
return false
– if ( luup.is_night () ) and ((os.difftime (os.time(), lastTrip) / 60) >= period) then
– return true
– else
– return false
– end
The code seems correct. Just to be safe I would add a default value for lul_light_level:
[tt]local lul_light_level = luup.variable_get (“urn:micasaverde-com:serviceId:LightSensor1”, “CurrentLevel”, 38) or 0[/tt]
Make sure that the device numbers are correct. If they are, then you should check the logs to find where the problem is.
You can find how to watch the logs in these places:
[ul][li]http://wiki.micasaverde.com/index.php/Logon_Vera_SSH[/li]
[li]http://wiki.micasaverde.com/index.php/Logs[/li]
[li]http://wiki.micasaverde.com/index.php/Luup_Debugging#Luup_logs[/li][/ul]
Thanks for your help.
Hi WB-AVL
I’m having a similar problem to you. I have been trying to get the following to work with no joy
– Low Light Level
local lul_temp = luup.variable_get(“urn:upnp-org:serviceId:LightSensor1”,“CurrentLevel”, 15) or 100
if (tonumber(lul_temp, 10) < 80)
then
luup.call_action("urn:upnp-org:serviceId:SwitchPower1", "SetTarget", {newTargetValue = "1"}, 6)
else
return false
Just wondered if you have been able to solve the problem yet?
Cheers
m0jon
I could not get it to work in the script example above but it is working in the script for another scene.
The following luup works:
luup.call_action(“urn:micasaverde-com:serviceId:HomeAutomationGateway1”, “RunScene”, {SceneNum = “32”}, 0)
if ( tonumber (lul_light_level) < 20 ) or ( luup.is_night() ) then
luup.call_action(“urn:micasaverde-com:serviceId:HomeAutomationGateway1”, “RunScene”, {SceneNum = “2”}, 0)
else
return false
