I just upgraded to the latest firmware 1.7.1598 and it seem to have broken my hue app. It says that it still is up and connected, but there is an ignore when I try to turn on any light. If I try to reconnect to the app it says error invalid service. Anybody else having this problem.
I had the same problem and fixed it by re-setting the config files in the hue settings:
device_file: D_PhilipsHue1.xml
imple_file: I_PhilipsHue1.xml
device_json: D_PhilipsHue1.json
Or you can uninstall the plugin and install it again but you will lose all the scene settings
