I have written many lines of code in Luup to have one thermostat control two other thermostats. However, ever since I upgraded to UI7, when the Mode is switched to heat or cool, the scene is no longer triggered. I’ve tried whatever I could think of, including recreating the triggers, but nothing seems to work. The strange thing is that the scene is triggered when the Mode is changed to Off, but not when to Heat or Cool. This used to work perfectly with UI5. Anyone knows why?
Second major issue I’m having is that when the nightly heal process runs, it seems to stop any running scenes. As I mentioned above, I have one thermostat controlling some other thermostats, and this requires my scene to run constantly every 10 seconds for many hours at a time. When one thermostat is controlling another thermostat and the scene stops, you could have bad consequences. For example, last night I woke up in the middle of the night because the temperature had risen to 90 degrees, because the scene had stopped and the upstairs thermostat failed to turn off the thermostat that actually controls the heater… On UI5, I had turned off the nightly heal and this problem was completely resolved. However, I can’t do that with UI7. Is there anyway to turn off the nightly heal? Or at the very least, have it not stop any running scenes?
