I’m using UI3 (1.1.228) and ran into a quirk. I have a ‘Sunset’ scene that is designed to turn on various lights in a staggered fashion. I do this by triggering the Scene at Sunset and then setting Commands on different lights so that they come on in a staggered fashion.
That works fine except… I discovered that if a light is already on, it is going out at sunset and then coming back on at the staggered time specified. I figured I must have just incorrectly set the Command to initially OFF instead of ‘Unchanged’. What I find, however, is that all commands that I had thought I had set to ‘Unchanged’ are now set to ‘Set Level’ on the dimmers and ‘Off’ on the appliance switches. Any attempt to reset these in the UI3 interface, however, does not save. In fact, it doesn’t even seem to stick since if I set it and then check it before a save, it has reverted again.
Has this bug been logged? Anyone else see this?
