I have an EVL-4 connected to my Honeywell 20P panel. I am also using a Vera Plus running UI7. I have the latest version of the plugin running on the Vera. The installer code is correct, and I am able to sync the panel time. However, when I run Read Panel Config I get an error and it does not pull in the zones. I do not have any faults or trouble codes.
No, getting the EVL-4 itself working went fairly smoothly. If you are still having problems and have not found this guide, it might be of help. file:///C:/Users/hutchinson/Downloads/Eyezon%20Envisalink%20Honeywell%20Installation%20Guide.pdf. It was more helpful that the quick start info especially on the details of the programming setup at the keypad. Once I followed it, I was able to log into the eyezon site and control the alarm w/o any issue.
Sorry, I should have been more clear. I have the EVL4 working great with the Vista 20P. I just can’t get the Plugin working. Since you got an EVL4 to work, I was wondering if there was anything special you had to do.
I have the latest version installed and am using a Vera Edge. The Plugin installs, locates my EVL’s IP address, then reports: EVL3 not found at forced/discovered IP address."
Any tips you can offer would be greatly
appreciated.
Open the device in the Vera and on the EVL3Vista tab, I entered the password for the EVL-4 and clicked SET and did the same on the line below it for the IP address.
I clicked the Reload Engine button just off to the side of where I entered the IP address
After a reload, I went to the Panel tab and entered the Installer Code and clicked Set.
That is as far as I have gotten, my next step was reading the Zones by clicking the Read Panel Config button just below where I entered the installer code.
In further troubleshooting, I made sure my Installer Code and Master Code were set right in the Codes tab. However, I had problems getting them to hold (since they were different than the defaults). So I went back to the Panel tab, scrolled to the bottom for Advanced and switched to the Variables tab. I went down to the User_Codes field and manually changed my Installer and Master Codes there. After typing them in, I left that screen up for about 10 minutes to give the Vera time to update the info. It seemed that if I moved too quickly off, the changes wouldn’t hold.
I went back to the EVL3Vista tab and reloaded the engine. Went to the Panel tab and clicked the Read Panel Config button again, but I am still receiving the same error message. Hopefully, you will get further than me.
