I cannot login remotely into my Vera 3 (UI5). I still get Vera Alerts messages, and I can activate scenes via Authomation. But the devices do not update on Authomation. When I try logging into Vera via my web browser, it stays on loading data for ages, the I get the yellow warning unable to communicate with your unit, with the try again, enable tech support etc message
Looking at Vera Alert messages, Vera is working fine, and I have remotely rebooted Vera (confirmed via Vera Alerts message)
I wonder if there is a problem with Mios servers ?
I contacted MCV tech support, and its all now working again. I do not know if they have been in my Vera, I had tech support enabled for them so it is possible. Still would be good to know what that was…
I have the same problem, i can not logg in remotely. It stays in loading data.how can i do for resolve this problem remotely because i’m on vacation.
thank you
