hello could you help me with support for this same case, I have read about flashing the vera edge through internal physical pins, I already have the usb cable with connection to pins but I don’t know how the process is done. Thank you
Hello @Miguel_Pinzon,
I would recommend contacting our technical support team at support@ezlo.com so they help you troubleshoot your controller.
Kind regards!
@Miguel_Pinzon I’ll reply to you on the ticket you created on our support channel. The information shared there is not supposed to be public, hence why I will not post it here.
