problem in wifi gateway similar to serial gateway for vera!!
problem in wifi gateway ( with ESP8266 ) similar to serial gateway (with arduino ) for vera!!
wifi gateway similar to serial gateway if unplug the power supply of gateway , settings is lost and back to default configuration… …
have any body a solution for save setting for always?
Hi ,
I am just starting to think about integration of an Arduino UNO board in Vera via the Wifi module ESP8266 connected to the Arduino serial port.
the purpose is to send HTTP request from Vera to Arduino to control motors …
