I have been having some problem with intermittent connection with my kwikset lock from Vera. from the trouble shooting section, I found the following:
Device stopped communicating with Vera ?
Please know that the possible reasons for your z-wave device(s) to lose communication with Vera is caused by one of the following :
-is that device a door lock? If so you will need to add in your z-wave network a security compatible (encryption capable) device which can relay the encrypted signal that the door lock needs to communicate with the Vera unit.
has anyone had similar issues? and what would be a security compatible (encryption capable) device?
thanks a lot.
this is usually the first post people put up, because we all love these locks and they are typically amongst the first purchases, so feel at home here.
And because they are new to Vera, folks with this problem tend to not have a very broad zwave network (very few devices).
If your Vera and the Lock are not close to each other, or if there isn’t an intermediary repeating device, you may have this problem.
Can you describe how far you lock is from vera, the construction of your home, etc.
You were able to successfully add it to the network, yes?
i was able to add it to the network. it is on a separate floor (in my house, the floor is wood, not concrete). direct distance probably 20 feet.
I do have 5, 6 other z wave products, but my other z wave products that is further away have had no issue. and another z wave lock one floor below (the functioning lock does have a sensor, not sure if that qualifies as " security compatible (encryption capable) device") in between.
I would have days without issue, but sometimes it just stops talking to Vera…
thanks a lot for responding.
a lot of things can influence the signal, especially if it is borderline.
if he other devices are battery operated like locks or motion sensors, they are not repeating.
you can try to add device that repeats somewhere in between. between floors, one ought to do if if it is midway between.
good luck
When you first added the lock, where was the Vera?
You need it to be right next to the lock within a couple of feet at most… Then when you take your Vera back to its home location it will need to conduct a heal process to sort out the routing. You can do this manually but ensure reconfigured device is unchecked or otherwise leave it to fix itself overnight.
You are looking for devices that support beaming. This is recorded as a “B” in the capabilities of the devices, if it has no “B” is does not support that capability. See below for more info if so desired.
http://wiki.micasaverde.com/index.php/ZWave_Command_Classes
