Was wondering if I could get some suggestions on how to prevent the following scenario.
Scene - Trigger
Scene Day On (Lupp filtered to only run during day) - Motion
Scene Night Off (Lupp filtered to only run during night) - Motion
Scene Off - No Motion or Light Switch Off
A problem happens if motion turns light off, and I’m still in the room, and I quickly cause motion…the Scene Off fires once on No Motion, and once when the light turns off from that scene (running the scene twice). If I don’t stay still while the lights off, I’ll get the order of Scene Off #1 from No Motion → Scene On from Motion → Scene Off #1 from Light Switch Off (switch turned off using Scene Off).
Can I filter via Luup if being called via specific scene X (Scene Off)? Does the calling scene a variable somewhere in Luu?
This is a WAF issue of making it appear unreliable.
