The title says it all.
PowermaxPro Panel
Vera 3
FTDI USB cable
My installation has been in place for about 3 years. I disconnected the PowerMax Pro panel from the Vera to move both to another room.
After reconnection, and clearing of the “Comm Loss” error on the panel, now whenever luup is restarted while the panel is armed, the powerlink mode comes back as unknown.
I can recreate this EVERY TIME.
Plugin working fine in powerlink mode. I see realtime sensor actions. Arm the panel, then any refresh (luup restart, ctrl-F5, edit notifications, etc), results in the POWERLINK UNKNOWN message. I can arm and disarm via Vera, without losing the powerlink mode, provided there is no vera restart.
In order to clear the issue, I force the plugin into standard mode, disarm with a PIN, restart luup, unforce standard mode, restart luup, then all is fine in powerlink mode.
Nothing else causes the the link loss/unknown. It will work for days as long as the panel is not armed. As soon as the panel is armed, if vera/luup restarts, the plugin goes into unknown mode, and stays there until I repeat the above process.
Any thoughts? Please help!
