Power Trigger ?
is there any way to have a trigger based on power consumption values ?
right now i checking regularly via a schedule, but i need something more “immediate”
the idea is simply to switch other items based on power consumption.
so turning on a TV with its own remote can be easy identified voa the power consumption level on its own FIbaro Plug or Power meter.
but i dont want to run a script every few sec to messure the power consumption on a set of plugs.
any ideas ?
Sounds like a job for PLEG…
right ! … easy solution …
http://apps.mios.com/plugin.php?id=3066
does the job well …
thanks !
You can also take a look at:
http://forum.micasaverde.com/index.php/topic,11076.msg78891.html
[quote=“jfp, post:4, topic:175831”]You can also take a look at:
http://forum.micasaverde.com/index.php/topic,11076.msg78891.html[/quote]
i think i go with your variant … much less equiped, but it does the job for me on a very tight footprint, i like that.
thinking already of alot other features to implement with this :wink:
