Hi I am using os.execute("curl to post data to a web site. It works just fine until there is some extenal issue (web site down).
When this happens, vera reboots. I have tried coding a pcall. This doesn’t help.Can someone dump some code to resolve this please?
If there are alternatives, please can you provide examaples.
Thanks for fror your switft reply but
That second option is far too complicated for my skill set… however after months trying to fix this I had a eureka moment… all I needed to do was code -m 5 on my curl staement.
This allows 5 secs for a response… now I will not get anymore vera reboots when the web site is down, or there are some other comms issues.
[quote=“mbaker171, post:1, topic:189283”]Hi I am using os.execute("curl to post data to a web site. It works just fine until there is some extenal issue (web site down).
If there are alternatives, please can you provide examaples.[/quote]
Hi there,
Can you post a small example(step-by-step) or tutorial, how you send the data?
I had a Razzbery for my z-wave network which i configured to post data to my website, but I am not sure how to do the same with the vera. Where should I put my code, what kind of code etc…
I will really appreciate it.
