I’m wondering if I can somehow send text from my ELK to Vera Alerts on my Phone, or to the Vera Alerts app within Vera which will redirect to my phone.
I’m trying to eliminate a few steps and by sending some alerts directly from my ELK would be great.
There is no LUA possible so it would have to be a raw string with a specified IP and Port…
Any examples would be appreciated.
Here is an example code in LUA talking to Android client …
You can do it from any other language supporting sockets!
You can do it from any device on the LAN … or WAN if port is forwarded from your router/firewall.
function VeraAlert(Host, Port, Msg)
local socket = require("socket")
local tcp = socket.tcp()
tcp:settimeout(3)
if (tcp:connect(Host, Port)) then
if (tcp:send(Msg)) then
else
print("Error Sending Msg")
else
print("Error Opening Socket")
tcp:close(socket)
So I have the port forwarded of 1024 on my router to my Phone. I also configured Vera Alerts app to listen on this port.
Can Putty be used to connect and send a string to Vera Alerts? I’m trying this as proof of concept first but I cannot connect under Raw/Telnet/SSH…
Next I downloaded an android app called TCP Socket. Set up as Server Listening on Port 1024. I can connect via RAW and have tried a combo of VeraAlert syntax but cannot get the VeraAlerts app to fire (Is it because this TCP program has now taken over the port?"
I can configure my phone to keep a constant connection via TCP with my ELK by connecting as a Client to the unsecure Elk Port “2101”. I even pointed VeraAlerts to listen on that port in hopes of it intercepting and announcing some of the text.
In the TCP app on my android I can see all traffic from VeraAlerts and even configured a trigger to send the text “VeraAlerts “Hello {tone:1}”” and it shows up on the phone’s terminal, however VeraAlerts does not “catch” this…
Can you provide some insight on how to accomplish this based on the info I’ve given?
I figured it out!
There is some configuration inside ELK to replace a Phone Number with an IP and to send Ascii to an IP/Port. It works flawlessly, and i’ll create another post to outline the solution.
EDIT:
Here is the solution; http://forum.micasaverde.com/index.php/topic,14032.0.html
