is there any way to tell which keypard is arming (or disarming) the alarm via the plugin? This would make it possible to unlock the door next to the panel being used to arm the alarm to make it easy to exit or enter (then re-lock it)
is it possible to know whether the panel went into Exit Delay due to an Arm:Stay vs an Arm:Away entry? This would make it possible to only unlock the door when exiting (user Armed Away)
I do not have time to test it, but possible answer to your second question would be setting up a relay and an output based on zone type. When you are setting up *80 output function, under “Activated by” select 2 for zone type. Then you have these options:
20 - Arming-Stay
21 - Arming-Away
31 - End of Exit Time
Hopefully Arming-Stay and Arming-Away are triggered right after keying the code in and not at the end of exit delay.
I know this is an old topic… but wondering if you were able to figure this out? I have the same issue, I want to create a scene that makes an announcement via my Sonos system when alarm is armed to Away mode only, not stay. But the same problem, they both first go into Exit Delay mode.
