Ok, I ran both codes and the read outs are below neither seemed to change anything. so as a run through here’s what I did. I originally uploaded the files through and on the vera3 UI5, what I re did to make sure they were there was re upload the files to root/overlay/sbin they also copied themselves to the root/sbin…
I chrom’ed the files altsteon & altsteon_cli to 755
I factory reset the PLM and reconnected it and made sure the garage hawk was included/added to it.
I then restarted the vera3 [unplugged it waited a few and plug it back in.
I made new PLM & Garagehawk panels.
I found a few code mistakes and I got to to get all the way to the door but it is not connected to the usb. Here’s copy’s of all the codes I ran after all the above…
And copies of what I set the panels to and a few pic’s… Did I miss anything? I think I have read that instruction sheet so many times I think I wrote it… LOL
let me know what we should try next… and thanks there for all your help!
copies of codes and results… They were ran in the order they are on the listing…
Code ran and results = dmesg [note only copied last half of print out]
usbcore: registered new interface driver rt2800usb
loop: module loaded
PPP generic driver version 2.4.2
ip_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 24
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
rt3883-ehci rt3883-ehci: Ralink RT3883 built-in EHCI controller
rt3883-ehci rt3883-ehci: new USB bus registered, assigned bus number 1
rt3883-ehci rt3883-ehci: irq 26, io mem 0x101c0000
rt3883-ehci rt3883-ehci: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
nf_conntrack version 0.5.0 (1991 buckets, 7964 max)
xt_time: kernel timezone is -0000
ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
rt3883-ohci rt3883-ohci: Ralink RT3883 built-in OHCI controller
rt3883-ohci rt3883-ohci: new USB bus registered, assigned bus number 2
rt3883-ohci rt3883-ohci: irq 26, io mem 0x101c1000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
Initializing USB Mass Storage driver…
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usb 2-1: new full speed USB device using rt3883-ohci and address 2
USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
usbcore: registered new interface driver belkin
belkin_sa: v1.3:USB Belkin Serial converter driver
USB Serial support registered for cp210x
usbcore: registered new interface driver cp210x
cp210x: v0.09:Silicon Labs CP210x RS232 serial adaptor driver
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
USB Serial support registered for Keyspan - (without firmware)
USB Serial support registered for Keyspan 1 port adapter
USB Serial support registered for Keyspan 2 port adapter
USB Serial support registered for Keyspan 4 port adapter
usbcore: registered new interface driver keyspan
keyspan: v1.1.5:Keyspan USB to Serial Converter Driver
USB Serial support registered for MCT U232
usbcore: registered new interface driver mct_u232
mct_u232: z2.1:Magic Control Technology USB-RS232 converter driver
USB Serial support registered for GSM modem (1-port)
usbcore: registered new interface driver option
option: v0.7.2:USB Driver for GSM modems
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
ftdi_sio 2-1:1.0: FTDI USB Serial Device converter detected
usb 2-1: Detected FT232RL
usb 2-1: Number of endpoints 2
usb 2-1: Endpoint 1 MaxPacketSize 64
usb 2-1: Endpoint 2 MaxPacketSize 64
usb 2-1: Setting MaxPacketSize 64
usbcore: registered new interface driver cdc_acm
cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
usb 2-1: FTDI USB Serial Device converter now attached to ttyUSB0
device wlan0 entered promiscuous mode
br-lan: port 2(wlan0) entering forwarding state
device wlan0 left promiscuous mode
br-lan: port 1(eth0.1) entering forwarding state
br-lan: port 2(wlan0) entering disabled state
device eth0.1 left promiscuous mode
br-lan: port 1(eth0.1) entering disabled state
device eth0 left promiscuous mode
device eth0 entered promiscuous mode
device eth0.1 entered promiscuous mode
ramips-wdt: timeout value 60 must be 0 < timeout < 25
CODE RAN = dmesg | grep “FTDI”
/sbin$ dmesg | grep “FTDI”
CODE RAN = ps -ef | grep alt
/sbin$ ps -ef | grep alt
4875 root 568 S /overlay/sbin/altsteon -p /dev/ttyUSB0
23653 root 1672 S grep alt
CODE RAN = ./altsteon -p /dev/ttyUSB0 -dd -f/sbin$ ./altsteon -p /dev/ttyUSB0 -dd -f
Debug Level : 2
[INFO ] [3/15/2014 - 23:15:50] - --| Starting altsteon!
[DEBUG] [3/15/2014 - 23:15:50] - Opening /dev/ttyUSB0…
[INFO ] [3/15/2014 - 23:15:50] - Running on non-apple Hardware
[DEBUG] [3/15/2014 - 23:15:51] - Sending : 0260
[ERROR] [3/15/2014 - 23:16:01] - PLM didn’t respond!
[INFO ] [3/15/2014 - 23:16:01] - Modem info :
[INFO ] [3/15/2014 - 23:16:01] - cflag = 00000CBE
[INFO ] [3/15/2014 - 23:16:01] - oflag = 00000000
[INFO ] [3/15/2014 - 23:16:01] - iflag = 00000804
[INFO ] [3/15/2014 - 23:16:01] - lflag = 00000000
[ERROR] [3/15/2014 - 23:16:01] - Failed to initialize PLM.
CODE RAN = dmesg | grep ttyUSB
/sbin$ dmesg | grep ttyUSB
Pic’s taken below right after all the codes were Ran!
Does that IP “127.0.0.1” need to be in place of the one on the usb panel? pic below?
Thanks and look forward to the next step…
