@ rigpapa
thanks for this awesome plugin/app
it has replaced several older plugins/apps that no longer worked properly in UI7
its very flexible and offers so much more than combo switch
one thing missing in comparison that I would like, if possible
is a pulse/poke/probe button found in the combo switch
i realize i can use the reset button, but this adds load on the system and takes about 30 plus seconds to reload that reactor
please let me explain one use case
in our bedroom i have 3 reactors that look at occupancy, room temp, home state, and current fan running state
all 3 have the same conditions except for the temperature range
this then decides based on the active reactor if the ceiling fan will run at low, medium, high, or simply off as its not hot enough
well, last night there was a power outage, but when it comes back on zwave devices do not restore last state
they are off even though the reactor state was still on
as the scene is not triggered if nothing changes
so when this happened the fans stopped running
with a poke/pulse/probe command
i can poke/pulse/probe the reactor as an example every 5 minutes
then the 3 scenes could have each 2 triggers instead of one
1- reactor tripped 2- reactor poked/probed/pulsed while tripped
by poking it every 5 minutes if the reactor is triggered but the fan is stopped the scene will re-trigger and the fan will be on
this would be a great addition
hopefully its something you can do
if you want to see how it was implemented in combination switch by futzle here is the github
i see you are working on a scene implementation for reactor
perhaps this may also somehow achieve what i am trying to do
i basically just need it to re-trigger periodically
