Only compatible with UI7
Introduction
This plugin allows to manage a virtual panel of alarms.
It’s designed to present, add, sort easily the alarms and mainly to handle acknowledgement for active alarms.
Installation
This is the beta version and is still in development.
You will find the plugin here : MiOS Apps
- Dashboard : just shows the active alarms (and acknowledgement).
- Plugin panel : shows all the alarms and allows to manage them (add, delete, move, acknowledge, …).
Activation and deactivation of alarms are done by luup.
Alarm status
local myPanelId = 123 -- Device ID of Virtual Alarm Panel
local myAlarmName = "Porte garage" -- Name of the alarm
-- Activate alarm
luup.call_action("urn:upnp-org:serviceId:VirtualAlarmPanel1", "SetAlarmStatus", { alarmName = myAlarmName, newStatus = 1 }, myPanelId)
-- Deactivate alarm
luup.call_action("urn:upnp-org:serviceId:VirtualAlarmPanel1", "SetAlarmStatus", { alarmName = myAlarmName, newStatus = 0 }, myPanelId)
Watch alarm status
For the moment it’s just possible by luup code.
function onAlarmIsActivated (lul_device, lul_service, lul_variable, lul_value_old, lul_value_new)
if (lul_value_new == alarmName) then
-- The alarm has just been activated
-- *** Your code here ***
luup.variable_watch("onAlarmIsActivated", "urn:upnp-org:serviceId:VirtualAlarmPanel1", "LastActiveAlarmName", myPanelId)
Alarm acknowledgement
For scalability reasons, the alarm informations are not stored individually in variables, but in a JSON array.
That’s why the acknowledgement information can not be retrieved in a variable, but has to be computed.
Here is an example of code you can put in a scene to decide if something has to be done according to the alarm acknowledgement.
-- Helpers
DeviceHelper = {
-- Get device id by its description (or id)
getIdByName = function (deviceName)
local id = nil
if (type(deviceName) == "number") then
id = ((luup.devices[deviceName] ~= nil) and deviceName or nil)
elseif (type(deviceName) == "string") then
for deviceId, device in pairs(luup.devices) do
if (device.description == deviceName) then
id = deviceId
if (id == nil) then
luup.log("[DeviceHelper.getIdByName] " .. tostring(deviceName) .. " doesn't exist", 1)
return id
VirtualAlarmPanel = {
isAlarmAcknowledged= function (panelName, alarmName)
local panelId = DeviceHelper.getIdByName(panelName)
if (panelId == nil) then
return nil
local lul_resultcode, lul_resultstring, lul_job, lul_returnarguments = luup.call_action(
"GetAlarmAcknowledge",
{ alarmName = alarmName },
panelId
if (lul_resultcode == 0) then
if (lul_returnarguments.retAcknowledge == "1") then
-- Alarm is acknowledged
return true
elseif (lul_returnarguments.retAcknowledge == "0") then
return false
-- Can't retrieve acknowledgement
luup.log("[VirtualAlarmPanel.isAlarmAcknowledge] Can't retrieve acknowledgement for panel " .. tostring(panelName) .. " and alarm " .. tostring(alarmName), 1)
return nil
if (VirtualAlarmPanel.isAlarmAcknowledged("My alarms", "Garage door opened"))
or
if (VirtualAlarmPanel.isAlarmAcknowledged(123, "Garage door opened"))
Sources
