The main point of this update is to properly handle some smoke detectors. All of the plugin files are in the attached ZIP file. The only files that have changed are L_RFXtrx.lua and J_RFXtrx.js.
RFXtrxPlugIn1.84.zip (129.6 KB)
Thank you for the update!
I can confirm that the smoke detectors work exactly as expected now. Brilliant job as usual and big thanks for keeping it possible to use Vera as the best universal gateway available.
Hi. Thanks for this update. Have been busy last months so I missed some time to play around.
I see 1.84 is out, and just checked my VeraEdge and if I look at the variables, it seems I am running 1.61.
Can I just upload all the files in this 1.84 zip file to update? Sorry, have done an update before.
Does this also include the Somfy bug from a while ago? ( to add a new remote?)
I’ve just posted the next release of the plugin. You should probably upload all the files from the zip file.
Thanks, will download 1.86. Gonna backup first and then update/upload my VeraEdge and watch…
