These are side table lamps and the primary source of light in the Family room and Bedroom. Right now they are plugged into standard z-wave dimmer modules and have regular light bulbs in them. Since there is no switch wired to control the outlets they are plugged into, I purchased some wall mount Cooper RF9500 wireless switches and attached them to the wall near the door to each room. I programmed the RF9500’s via z-wave Direct Association through the Vera to turn on/off/dim the z-wave dimmer modules the lamps are plugged into. Now when you enter, you use the RF9500 switch to light up the room.
My goal would be to keep that functionality, but add the ability to have different colored light for watching TV/movies. Since the RF9500 won’t function as scene controllers and only work via direct association, I maybe out of luck, even with something like Hue bulbs since they probably can’t use Direct Association either.
