It totally works!!! Awesome job!!! Thanks so much for all your efforts to fix this! ![]()
BTW, I am on UI5.
For alpha code, it worked great, and didnāt require me to do anything beyond connecting with the gateway.
Suggestions:
- Iād rename the button from Login to Connect to Gateway and make the note about the green sync button very obvious.
- Iād show that the sync worked visibly on the screen.
- Iād make it auto-sync at connect and then update the dialog to say all good to go again.
THANKS!
My wife would have been annoyed if sheād discovered the autolights broken again.
We had a 2.5h power outage, and the UPS powering the non-essential automation gear went down first. Tempted to move the TCP gateway to the UPS after this fiasco.
I followed OP instructions in a previous post on adding this alpha code. Unfortunately even after adding the gatewayās IP (and confirming I can ping it from my laptop), the message in the configuration when I try to hit Login is that there is no gateway IP. What am I doing wrong I canāt seem to get the Vera Edge to recognize the IP Iām typing in under āadvancedā?
Same for me (although I have a VeraLight). Canāt seem to get Vera to find TCP.
@rEVOLVE and @jpope42: Can you check the firmware version of your TCP Gateway? Also, are the Vera and TCP units plugged into the same router/access point?
My TCP firmware is version 3.0.7.4 Yep, both devices are plugged in to the sam network
Well, I just tried the procedure again, this time it worked! I must been doing something wrong last night.
Thanks for your help!!
Iāve found similar behavior sometimes when adding new bulbs via the TCP mobile app - the gateway goes into sync mode, but just doesnāt seem to pick things up, and then eventually succeeds on subsequent attempts.
[quote=ājpope42, post:67, topic:179548ā]Well, I just tried the procedure again, this time it worked! I must been doing something wrong last night.
Thanks for your help!![/quote]
Also at 3.0.74 and moving the TCP control hub to the same switch as my Vera Edge is one of the first things I did.
I either get a message at the top of the Vera UI saying TCP Lighting[32] : Startup LUA failed or one indicating thereās no IP set for the gateway, even though Iāve gone into advanced and entered the proper address. Iāve set my router to reserve this static IP for this āLightingā device by MAC address.
If you could send me any log entries containing the text āTCPLightingā, that would help to dig deeper. If you donāt already have it, the InfoViewer plugin provides a nice way of filtering and accessing logs.
[quote=ārEVOLVE, post:69, topic:179548ā]Also at 3.0.74 and moving the TCP control hub to the same switch as my Vera Edge is one of the first things I did.
I either get a message at the top of the Vera UI saying TCP Lighting[32] : Startup LUA failed or one indicating thereās no IP set for the gateway, even though Iāve gone into advanced and entered the proper address. Iāve set my router to reserve this static IP for this āLightingā device by MAC address.[/quote]
Uploaded the Alpha code and all is good now. Thank you pmnb!
Mine is having the same issue but they are still connected with the wink hub.
Dan
Hi Dan,
Can you clarify on a few points that will help me sort this out:
[ul][li]What Vera UI version are you using?[/li]
[li]What is the firmware version of your hub?[/li]
[li]Did you try the alpha version of the 2.0 plugin posted above?[/li][/ul]
[quote=āBiGGDaN, post:72, topic:179548ā]Mine is having the same issue but they are still connected with the wink hub.
Dan[/quote]
This worked for me on UI7. Thanks!
Iāve submitted the v2.0 plugin for MiOS marketplace approval.
In the meantime, the v1.0.1 (for TCP gateway firmware prior to 3.0.74) and v2.0 (for firmware 3.0.74+) can be downloaded and manually installed using the instructions posted at [url=http://code.mios.com/trac/mios_tcplighting/wiki]http://code.mios.com/trac/mios_tcplighting/wiki[/url].
Iāve incorporated some of your suggestions in the 2.0 plugin that Iāve submitted to the marketplace:
[ul][li]The Login button has been changed to Pair[/li]
[li]If pairing is successful, the sync function will be automatically executed.[/li][/ul]
Your suggestion about clearly indicating pair/sync success is a good one, but will require some code rework, so it will have to stay on the āto-doā list for now.
Suggestions:
THANKS!
We had a 2.5h power outage, and the UPS powering the non-essential automation gear went down first. Tempted to move the TCP gateway to the UPS after this fiasco.[/quote]
The v2.0 plugin is now available on the MiOS marketplace.
Hello! Thanks for all the work on this!
The alpha code was working great for me, but the update triggered while I was away and now it is no longer working with the new 2.0 plugin. I tried completely deleting the device and starting over, but I still get stuck after the Sync bit. I get a āDevice not readyā when I try and use the newly created devices that get synced over.
Logs:
50 02/17/15 18:41:16.101 luup_log:122: TCPLighting: synchronize_gateway - start <0x2d54d680>
50 02/17/15 18:41:16.101 luup_log:122: TCPLighting: create_child_devices - gateway is initialized <0x2d54d680>
50 02/17/15 18:41:16.102 luup_log:122: TCPLighting: create_child_devices - creating child with did=360262088736156116, name=Room Lights <0x2d54d680>
50 02/17/15 18:41:16.103 luup_log:122: TCPLighting: create_child_devices - creating child with did=216584995899636507, name=Hallway <0x2d54d680>
50 02/17/15 18:41:18.118 luup_log:122: TCPLighting: schedule_next_poll - timer set LEAK this:-188416 start:1515520 to 0x110c000 <0x2d54d680>
50 02/17/15 18:41:18.118 luup_log:122: TCPLighting: synchronize_gateway - end <0x2d54d680>
6338 root 1672 S grep TCP
09 02/17/15 18:41:30.536 JobHandler_LuaUPnP::Run device 122 TCPLighting room 0 type urn:schemas-pmcode-org:service:TCPLightingGateway:1 id parent 0/0xa12228 upnp: 0 <0x2b084000>
50 02/17/15 18:41:53.324 luup_log:122: TCPLighting: tcplighting_plugin_startup - start <0x2b9b7680>
50 02/17/15 18:41:53.325 luup_log:122: TCPLighting: synchronize_gateway - start <0x2b9b7680>
50 02/17/15 18:41:53.325 luup_log:122: TCPLighting: get_gateway - calling tcplighting_gateway_init, IP=10.19.76.113 <0x2b9b7680>
50 02/17/15 18:41:54.346 luup_log:122: TCPLighting: sync_child_devices for 122 - updating child 123 Spa Lights LEAK this:196608 start:1781760 to 0x109d000 <0x2b9b7680>
50 02/17/15 18:41:54.346 luup_log:122: TCPLighting: update_attr - device_number=123 <0x2b9b7680>
50 02/17/15 18:41:54.347 luup_log:122: TCPLighting: update_attr - attr_name=manufacturer <0x2b9b7680>
01 02/17/15 18:41:54.347 LuImplementation::StartLua running startup code for 122 I_TCPLighting1.xml failed <0x2b9b7680>
Little more:
09 02/17/15 18:55:09.754 JobHandler_LuaUPnP::Run device 122 TCPLighting room 0 type urn:schemas-pmcode-org:service:TCPLightingGateway:1 id parent 0/0xed0210 upnp: 0 <0x2aebd000>
50 02/17/15 18:55:28.387 luup_log:122: TCPLighting: tcplighting_plugin_startup - start <0x2b7f1680>
50 02/17/15 18:55:28.387 luup_log:122: TCPLighting: synchronize_gateway - start <0x2b7f1680>
50 02/17/15 18:55:28.387 luup_log:122: TCPLighting: get_gateway - calling tcplighting_gateway_init, IP=10.19.76.113 <0x2b7f1680>
08 02/17/15 18:55:28.829 JobHandler_LuaUPnP::HandleActionRequest device: 122 service: urn:pmcode-org:serviceId:TCPLightingGateway1 action: Synchronize LEAK this:12288 start:1007616 to 0x149e000 <0x2f293680>
08 02/17/15 18:55:28.829 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:pmcode-org:serviceId:TCPLightingGateway1 <0x2f293680>
02 02/17/15 18:55:28.830 JobHandler_LuaUPnP::RunAction device 122 action urn:pmcode-org:serviceId:TCPLightingGateway1/Synchronize failed with -911/Device not ready <0x2f293680>
50 02/17/15 18:55:29.438 luup_log:122: TCPLighting: sync_child_devices for 122 - updating child 123 Spa Lights LEAK this:-28672 start:1056768 to 0x14aa000 <0x2b7f1680>
50 02/17/15 18:55:29.439 luup_log:122: TCPLighting: update_attr - device_number=123 <0x2b7f1680>
50 02/17/15 18:55:29.439 luup_log:122: TCPLighting: update_attr - attr_name=manufacturer <0x2b7f1680>
01 02/17/15 18:55:29.440 LuaInterface::CallFunction_Startup-1 device 122 function tcplighting_plugin_startup failed [string āā¦ā]:135: attempt to concatenate local ānew_valueā (a nil value) <0x2b7f1680>
01 02/17/15 18:55:29.440 LuImplementation::StartLua running startup code for 122 I_TCPLighting1.xml failed <0x2b7f1680>
Eek - Looks like I may have some sloppy logging code. Try uploading the attached file and see if that fixes things.
[quote=ājustroach, post:78, topic:179548ā]Hello! Thanks for all the work on this!
Logs:
Little more:
01 02/17/15 18:55:29.440 LuImplementation::StartLua running startup code for 122 I_TCPLighting1.xml failed <0x2b7f1680>[/quote]
Suhweet!
Worked like a charm! 2.0.1?
You need a BTC donation addressā¦
