I am trying to figure out how I can use the ping sensor to ping two separate addresses. (2 iphones) Everything on here seems to be from UI4, I’m guessing. I just downloaded the app through UI5, no messing with files of any kinds so I am a little lost.
Also when using PLEG, can I just write conditions as I need them for different events or scenes or whatever you call them. My first set of conditions works perfect but the others don’t. Do I need a second instance of the app to do other stuff… i.e. if condition 1 and 2 are not will 3 and 4 run assuming everything else is correct and 3 and 4 don’t reference 1 and 2??
Thanks…
