Hi, I’ve just got a Vera Lite box and am in the process of setting it up. I have downloaded PLEG - which I have got working and PLTS which I can’t get working. In PLTS, under settings, the pages for Inputs, Conditions and Actions are all blank. Is there a step that I have missed between installing the app and setting it up?
same here.
Using UI7 (updated before reading) on a Vera Lite
Related info
PLEG works marginally. Actions require a reboot to be implemented, after reboot instructions are missing.
I suspect PLEG is fine, and UI7 is the culprit, nonetheless it is rendering a hopeful platform not usable. I don’t think PLEG is making RTS wealthy, but he is certainly a few cases of brew lighter because of the issues.
