Hi, I’ll hope I’m in the right subthread:
I’m a new owner of a vera plus device. Uncomfortable in Germany only the Vera devicis available to buy and after that I recognise, that the device is near end of live. The device contains the last released Firmware. A try for update to the beta FW failed and the Vera plus started again -after internet access- with the last released Firmware.
I’ve a Fibaro 2 way walli switch (Walli). The 1channel has the association group 1(main). If I switch manual the channel, the update in vera is received in time. If I switch channel 2, the update received earlierst after the poolling time (1Min). That’s to late for valid scenes. So I try to add the association 2/4 (Channel 1) and 3/5 (Channel 2 ) as association to the device “zwave” , in the hope, that the status will be available in the gateway in time.
Following issues are occurred:
*Vera lost the 2 child-devices for a while
- Vera lost the renaming name of the 2 child devices and after time channel 1 and 2 contains the original name
- An error occurred, that the profil couldn’t save/read from the node (Walli Switch).
- The association to “zwave” didn’t show any expected result:
- more the main device didn’t response anymore for ON/OFF
Does anybody knows, how I can assign the device, so that I received the real status in vera also after manual ON/OFF so that the events could be used in a scenario?
Plan is
- a motion sensor should be armed, if channel 1 OR 2 is ON (Manual)
- if no more motion is detected, Ch1 and Ch2 should be switched OFF, motion should dearmed
- If a motion in between detected, the current switch should be untouched
- After S1 or S2 are OFF, a delay longer a the timeout of the PIR, let time to switch the light with a motion ON again. No disarmed of the motion sensor should be occurred
- If Channel 1 AND Channel 2 switched manual OFF, the motion sensor should be disarmed
** and not switched in the meantime in between a channel once again ON (Between channel X OFF and still Y ON) or channel X and Y are OFF and a person leave the room.
For this, a fast status change of channel 1 and 2 in vera are neccessarry. The poll time which could be min used is to long for this scenario ![]()
