Pleg Variable
Hi!
I use a condition to average two temperature sensor. This give me a variable has result for this condition. I want to create an action that set another device with this value. Is it possible?
Of course …
Say you have a condition:
Sum (Sensor1 + Sensor2) / 2
In the actions for Sum you can:
Specify some action that has a variable value, i.e. set the temperature set point of a thermostat to 50.
Then go into the advanced editor and change the 50 to {(Sum)}
Or if there is not an appropriate action and you want to set some arbitrary device variable:
then in the advanced editor for actions … use the SetVariable action for the current PLEG.
You will have to specify the target device, serviceId and variable name, then use a value of {(Sum})
Super! working #1 thank you:)
