I had this working when I used the Vera 3. I upgraded to Vera Edge, and now I can’t get it to work. I am including screen shots. Also I can’t get “Actions” set to “immediate - 1”. What am I doing wrong?
What happens when you try to EDIT the action ?
What UI7 version do you have ?
What PLEG/PLC versions do you have ?
Hint … the PLEG/PLC versions are important if you have an OLDER UI7 release. If you have the LATEST UI7 release you need the LATEST PLEG/PLC versions.
I am running firmware version: 1.7.1707. PLEG version: 7.47. PLC version: 7.48. I edit the action as you stated in your email, and it still did not change. Actually I edited it a few times just to check if it would work.
Am I missing any steps in the programming?
It is working now! I edited the action, add a device, change the state of the device, then save. I did that for each action. Once that is done, I do a refresh. Then I edit again and change the “NewTargetValue” to the appropriate value (I or 0).
@Mudd, now that you were successful in getting your PLEG working would be so kind and post your latest PLEG report for others to view and learn from? thanxs in advance Mike
Here is the report. I hope this is what you are looking for.
@Mudd, many thanxs. Yes it is what I was asking for, one of my gripes is that through out the PLEG threads we get initial examples but a lot of times never see the working example(s). Personally it provides valuable insight into various techniques that folks out there have solved that can be adapted for one’s personal needs. Mike
