I have 5 triggers, all evaluating my master bedroom temperature. All of a sudden one of them is not triggering although it should. These are the triggers, and the current temperature according to the master bedroom temperature device is 23.3 degrees. So all of them are in the right state, except for bedroomhot1. So i changed bedroomhot 1 to 19 degrees, still false. Set it to below 25 degrees, still false. No idea why. I notice this at about 22.00, and have changed it a few times (see above) but state is not changing no matter what i set it to. I have reloaded Vera a few times, no change.
Triggers
Name Description Last Trigger State
OutsideHot Temperature outside temperature goes above 19 degrees 2013-09-30 16:47:22.689 false
AC_Auto_ON MultiSwitch Switch 3 is turned on 2013-09-30 22:13:11.637 true
RWindowOpen Window Right is tripped 2013-09-30 22:06:38.065 true
LWindowOpen Window Left is tripped 2013-09-30 22:06:43.475 true
BedroomHot1 Temperature Master Bedroom temperature goes below 23 degrees 2013-09-30 18:29:41.085 false
BedroomVeryhot1 Temperature Master Bedroom temperature goes above 26 degrees 2013-09-05 20:30:17.819 false
BedroomCold1 Temperature Master Bedroom temperature goes below 21.5 degrees 2013-09-29 08:09:10.954 false
BedroomVeryCold Temperature Master Bedroom temperature goes below 16 degrees 0 false
