PLEG Startup Lua failed
Have built a lot of different PLEG conditions the last months and aside from user errors it’s been working great. However, today when adding a new virtual switch as a PLEG trigger, witch is used in a PLEG condition something must have gone wrong. I now only get “PLEG Startup Lua failed” when reloading LUUP. I have also tried checking the logs, but I can’t find any. I’ve gone to PLEG → Logs and logged in, but it just says “No records found”…? Using a Vera Edge with UI7 and licensed PLEG.
Help very much appreciated since a lot in this house is run by PLEG nowadays!
Thanks in advance!
EDIT: My inputs, conditions and triggers doesn’t show up any more under PLEG → Inupts/conditions/actions. I’m using version 7.47 of PLEG and 7.48 of PLC. Latest Vera Edge UI7 firmware 1.7.1569 has been running without issues since a few days.
