PLEG slow?
I have wired my AC doorbell through a optocoupler connected to a sensor built on mysensor.org. I’m using PLEG to turn on some z-wave lights based on the sensor but the response is very slow (10 sec).
I have ssh in to my vera and according to the logs the sensors status change is almost immidiate. The device in Vera UI changes about 1 second later but the lights takes about 10 seconds to turn on. Turning on the lights directly through Vera UI is almost immidiate.
I’m running Vera UI7 1.7.1569, PLC 7.48 and PLEG 7.47. I have three instances of PLEG.
Is this normal for PLEG? If not, how do I best troubleshoot this?
You can see PLEG send the commands in the log file as well.
Is there a delay in sending the commands or in your Z-Wave network handling them ?
Changing the device variable IgnoreTripTime from 10 to 1 seems to have solved my problem :slight_smile:
As far as I can tell this may have to do with some bouncing problem with my sensor.
