PLEG Sending Message Even When Sensor Is NOT Armed
I have installed 4 Schlage window and door sensors and installed on Vera. They show up as motion sensors but reading on here that seems to be the norm. I used PLEG to send PushOver notification when the door is tripped/opened. This works (a door chime so to speak). But I wanted to use PLEG to have it send a different PushOver notification if the device is tripped and armed. However if the sensor is in armed or bypass mode I still get both notifications. Need to try to get this sorted out before I put a siren on the system.
PLEG input TFrontDoorArmed = “Front Door Sensor armed is tripped”
Condition FrontDoorArmed = TFrontDoorArmed
Action PushOver Notification
What am I doing wrong?
I want two different notifcations
1 - Door Tripped and in bypass
2 - Door Tripped and armed
See: this thread.
