PLEG schedule not firing due to restart
I have a schedule to turn on my hot water It is a PLEG action firing when the condition is true, condition is my schedule). I had a few times now that the hot water did not come on, and looking at my Vera Alerts logs, I can see I had a Vera startup just at the time when the water should have turned on. Now, to make sure the water turns on even when Vera restarts, I have 2 ideas. I could add a delayed action to my action and just repeat the action to turn on the water heater after 2 minutes. Or I could add a second schedule which is 2 minutes later and fires the on command again.
Would that work ? Or is there another way ?
