PLEG Schedule causes a Restart
Hi. Need some help. Today, Sunday, March 1, PLEG is stating sWeekend is not True. if I force it, by DO IT NOW, it changes to true, then reboots, and the status that occurred on March 1st seemingly never happened.
I have attached log, status, and report, and some screen shots as proof the sWeekend was true for several seconds…
Please let me know 1) if I have too many properties, conditions, etc, and 2) what is causing this loop of reboot and revert…
Thanks all!
Sounds like you are running out of memory trying to save the State of your Vera device.
You will need to Verify by looking at why Vera is restarting in Vera’s log …
Is this a Vera Lite ? Which UI ?
Richard - it is a Vera lite, on UI5. Tried opening a command prompt on OSX, and SSH IP address, got connection refused before asking me for credentials…I will look for some pointers on line…
Edit - “ssh remote@IP” results in connection refused. Same command on secondary vera results in an expected password challenge. I rebooted primary , but still cannot login to primary vera via ssh
