PLEG - Ramping
Searched the PLEG section for Ramp, but did not see anything that helps me understand the STARTRAMPTOLEVEL dropdown function. Are these valid commands for all zwave dimmers?
In the attached picture, I was trying to get the accent lights to ramp to zero in 5 seconds. ( a test timeframe.)
How can I best do this using PLEG?
I described an approach to this in Using PLEG to set Device Variables.
Rex - Thanks, I will try that, and I see the picture was blank, I have reattached.
As I explore the features of PLEG, please look at the attached PDF ,and if you can explain the concept of these dropdowns.
I was hoping for a simpler way to do the ramping up / down, and want to better understand what I configured in the picture actually accomplishes. To a new PLEG user, it would seem the options I selected, would ramp the light down to 0 after 5 seconds.
Thanks!
