would it not be better to use use them? and if so how would one use them with this PLEG example, I assume it would no longer be a device property but rather a My Modes > Vacation with a unique name? Mike
I have it working fine. Been testing all day and it is doing fine. So disregard my previous post.
Thank you all for helping me out with this. I think you should include the as an example in your PLEG docs. A lot of people would benefit from this function.
If you want to use MCV modes … you PLEG allows you.
I do not plan on using Vera Modes …
For me I can have
Vacataion, and Vaction + Night, Away, and Away + Night, Home, Home + Night
Alright Richard,
I’m being a little thick… ::), Instead of using the Vera Mode your using virtual switches or are these PLEG inputs for each of you modes?
Richard,
Thanxs for clarification, I’m assuming that when your on Vacation that you select both; Vacation and Vacation + Night? I would have thought that Vacation + Night could have been solved within a condition statement using Day/Night as an Input, obviously I’m missing something?
The reason I’m asking fundamental questions is that for the novices of us not all things are totally clear (I’m not always seeing the blonde amongst the one’s & Zero’s - Matrix) any help from you is greatly appreciate and helps us make a better HA solution. That’s why I will ask others to post their latest PLEG solutions as they are great working examples/resources to used and modified. Mike
I downloaded DeusExMachina from the official VERA app store, but I’m pretty sure it screwed up my PLEGs. They all came up empty with the error message “ says Error Reading Data”. I restored a backup taken shortly before I installed Deus and the PLEGs came back to normal.
Please accept my apologies for maligning Dues incorrectly, it was just one of life’s unfortunate co-incidences that it happened immediately after I installed your plugin (or maybe the downloading of any app triggered the update of another app?)
