Aaron
December 12, 2014, 6:02am
#1
updated
Three consistent issues just started with update to 7.27 items that have not been changed in a LONG time
Device status not correct - AwayMode shows true, should be false
Condition not triggering when True.
Away AwayMode OR !Occupied
shows true but Action is not firing : only has 1 action, RunScene
Condition showing True when they should not be
Disarm DisarmMode or ((Aaron or Robyn) and DayTime) or (EightAM and Occupied)
shows True, should be False
Please see attached screenshots & debug log
It was working fine for a long time before 7.27 installed.
Actions only fire when conditions change state from FALSE to TRUE. (Unless repeats are turned on for the condition).
You will have to identify why/how your away switch got set (or did not get reset).
Aaron
December 12, 2014, 4:01pm
#3
Richard,
PLEG is reading some switches incorrectly. Take a look at the screens I posted, you can clearly see that a few MultiSwitches are False but PLEG shows as True - thus, Condition evaluations are not changing.
To “fix” this, what I did was manually set the AWAY button… then PLEG started seeing it correctly.
So… is there a possibility that Vera was showing the correct button state on the web page, but PLEG is reading a value that Vera was incorrectly providing?
PLEG DOES NOT READ THE STATE of ANY device Variables (except at startup)
Vera Tells PLEG when it changes a Variable. If the state is wrong its because I did not get a CHANGE notice … or I have a bug.
Aaron
December 12, 2014, 4:45pm
#5
OK, I did not know that. Thx for explaining.
I had the debug log turned on but it is VERY difficult to follow - a ton of stuff on there and so many values and conditions are evaluated.
Is there a way you can make a trimmed-down version of the debug which only shows what “changes”…
Change notifications PLEG received
what Conditions evaluated from False to True
what Conditions evaluated True, with Repeats on
This would make finding problems and seeing exactly what is is doing for those of us that are not PLEG experts, much easier?
