I have an Echolink Tilt-ZWAVE-2 tile sensor for my garage door. It works fine; Vera sees it as a motion detector, and show it as being tripped when the garage door is up (and the sensor is tilted), and shows a non-tripped state when the garage door is back down (and the sensor is vertical again).
Pleg, however, always sees it as being not tripped, even when Vera shows it as being tripped.
Report:
Triggers
Name Description
Garage_Door_Down Whenever Outside Garage Door stops detecting motion whether is armed or disarmed
Garage_Door_Up Whenever Outside Garage Door detects motion whether is armed or disarmed
I’ve attached two images showing the Vera device in both the motion detected and not detected states, and the PLEG status taken a few seconds after Vera showed the changed state. Note that Vera continues to show “motion detected” as long as the door is up and the sensor is tilted; it doesn’t time out after a while.
So, my questions:
- Is anyone else using this tilt sensor, and is it working for you with PLEG?
- Am I doing anything wrong?
