Re-Posting in the PLEG forum;
Is there a way to send a message within PLEG with Homewave Push Plugin? I see the option to select the device and the send message, but where would I enter the text to send?
If there is no argument in the Advanced tab for for Actions (or Scenes) then this is an incomplete implementation in the Push Notifications plugin’s file D_XXXX.json
right, so it is a problem with the Homewave plugin. I see.
I assume the same happens in trying to add it to a Scene.
I use the same code as Vera’s Scene Editor.
