PLEG help for a dummie please!
I don’t understand this problem with PLEG. I’m sure it’s me, but please help.
I use an Elk output to control my water valve. Works fine
I also have an Elk zone hardwired on my water valve. Works fine
I have a booster pump plugged into a Z-Wave socket. Works fine
If my water valve closes, I want the pump to turn off. So I did the following PLEG thing. Seems simple enough even to me.
Checking the Pleg status, it is all working perfect (true and false), but my pump is not turning off OR on.
Remember, the valve and pump control work in Vera, Homewave and even Elk Pro. The devices are happy. And PLEG says it is also happy.
But if I close the valve, the pump could care less.
Any ideas???
Trigger:
WaterValveOpen WATER VALVE sensor is not tripped 8/12/2013 9:42:38 PM true
WaterValveClosed WATER VALVE sensor is tripped 8/12/2013 9:38:02 PM false
Condition:
WaterValveOpen WaterValveOpen 8/12/2013 9:42:38 PM true
WaterValveClosed WaterValveClosed 8/12/2013 9:38:02 PM false
Actions for Condition: WaterValveOpen
Device Action Arguments
Water Pump SetTarget newTargetValue=1
Actions for Condition: WaterValveClosed
Water Pump SetTarget newTargetValue=0
It looks like you have two similar topics open. Please do not double post.
  • Garrett
