Currently using PLEG to configure my 3 Trane thermostats for the 3 Zones in my house. A feature benefit is the Energy Saving Mode (ESM) which will drop the temperature set points for heat/cool to bare minimums. For reference, I use H-60/C-80for this setting.
The issue I have, is that if ESM is turned on (which I have a virtual switch for), when I turn ESM back off (via the switch), the thermostat reverts to the set points that were set before the ESM was set. For example, let’s say I have 2 Schedules input into PLEG (9AM and 11AM). When 9AM hits, the PLEG successfully changes the temp to 68/75. When 11AM hits, PLEG successfully changes the temp to 65/79. The problem, is that if ESM is turned on around say 10AM, and turned off around 1PM, the thermostat goes back to 68/75 per the last setting it had.
Anyone successfully running a schedule with Trane Thermostats that have the ESM function? OR perhaps a similar thermostat that behaves similarly? I’d like to get this resolved once and for all so I can effectively program the thermostats to drop when I leave the house and return to whatever the scheduled temperature is according to the schedule being set.
