PLEG errors in log
I’m learning how to debug code on Vera and am tailing the UPnP log. I noticed that every once in a while, I get a cluster of these. Anything to worry about?
[tt]01 10/26/13 7:31:58.853 luvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn’t exist <0x2ff3d680>
01 10/26/13 7:31:58.856 luvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn’t exist <0x2ff3d680>
01 10/26/13 7:31:58.858 luvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn’t exist <0x2ff3d680>
01 10/26/13 7:31:58.861 luvd_get_info /etc/cmh-ludl/S_ProgramLogicEG.xml.lzo doesn’t exist <0x2ff3d680>
01 10/26/13 7:31:58.863 luvd_get_info /etc/cmh-ludl/S_ProgramLogicC.xml.lzo doesn’t exist <0x2ff3d680>
[/tt]
Ignore the extension … do you see a file with the same name from the Vera DashBoard → Apps → Develop Apps → Luup Files ?
I have S_ProgramLogicC.xml.lz and S_ProgramLogicEG.xml.lz in “Luup Files”.
Then I do not know why you arg getting those errors.
If the files were really missing … you would have problems.
if I look in the /etc/cmh-ludl directory, I see S_ProgramLogicEG.xml.lzoenc and S_ProgramLogicTS.xml.lzoenc
with the lcoenc extension rather than just lzo.
That’s correct.
That’s why I told you to ignore the file extension (part of the name after the .)
Vera can decrypt the S_ProgramLogicEG.xml.lzoenc → S_ProgramLogicEG.xml.lzo
and the decompress to: S_ProgramLogicEG.xml all on the fly.
After months of ignorant bliss, I started looking into my log file this week and I, too, am getting this error. The files exist, and PLEG is functioning, but it throws off about 10 of these errors in a row every 30 seconds.
Just like with memory usage, I can feel my technical hypochondria coming on! :slight_smile:
I will eliminate these errors with the next PLEG/PLTS release … but I do not think they are causing any problems.
I get these errors now with 7.11… is this a benign thing that is still out there or could this be causing me problems? (My outward system is about 40 ‘Vera Startup’ messages a day…)
Getting this error in 7.11 too. It is weird because it was not happening a few days ago.
