I watch a tutorial on PLEG and trying to use that as a basis for my logic. all im using is the 8 way vitural switch and setting a condition to true when 1 and 2 are both off. The action of that would be to trigger switch 8 on, however, the video shows that a very easy way of creating actions. With ui7, all i see is lua code to write. Am i missing something simple? I have 2 inputs and 1 condition and have no idea how to create the action.
You will most probably find that the video has been made for UI5.
With UI7, PLEG has a different Action editor. See [url=http://forum.micasaverde.com/index.php/topic,29896.msg212145.html#msg212145]http://forum.micasaverde.com/index.php/topic,29896.msg212145.html#msg212145[/url] for more details.
Thanks! I was able to see the devices now. However, it appears that the save button is grayed out. I can still click it and i guess that means it must be enabled, but it appears that my condition is never met to work on the virtual switch or a light from one of my listed devices.
Inputs
i1 - Multiswitch 1 is off
i2 - Multiswitch 2 is off
conditon
i1 and i2
action
to turn on multiswitch button 8
You need to Reload Vera for the new PLEG configuration to become active.
Thanks. I did get something working after a full reboot unplugging the device. Is there a way to issue a reboot on ui7 without have to physically unplug?
The next release has a button on PLC panel to reload.
