This instance of PLEG (used for my alarm triggers/conditions/actions) was in BYPASS and still managed to trigger an alert:
Unit Notification <noreply29@notification.mios.com>
5:20 PM (10 minutes ago)
to house
Your trigger "Alarm Tripped Home" occurred.
The originating device ID:59 PLEG Alarm in room:
The ID is: 257384235
Code: ConditionSatisfied Value:AlarmTrippedHome
The condition is:
Name Repeat Expression
AlarmTrippedHome No (StaySet OR GoodnightSet) AND (FrontDoorTripped OR GarageDoorTripped OR RearDoorTripped)
However, the input hadn’t been triggered:
StaySet MultiSwitch Switch 2 is turned on false 2014-06-11 16:19:19.633 2014-06-11 16:55:34.403
VacationSet MultiSwitch Switch 4 is turned on false 0 0
(MultiSwitch switches 1-5 are a group, and Switch 1 is turned on, the rest are all off…)
Even the notification apparently wasn’t sent… ?!
Name Description Users Last Sent
Alarm Tripped Home PLEG Alarm has satisfied condition: AlarmTrippedHome tomasone 2014-06-11 16:53:16.28
How could this have happened? What (if anything) am I missing?
Edit: I just got another notification that it was tripped again. I have turned on debug mode. Here is the current input status, taken after that second notification:
Triggers
Name Description State Last True Last False
FrontDoorTripped Front Door armed is tripped false 2014-06-11 16:53:16.274 2014-06-11 17:00:17.834
GarageDoorTripped Garage Door armed is tripped false 0 2014-06-11 16:55:34.536
GoodnightSet MultiSwitch Switch 5 is turned on false 2014-06-11 00:00:41.641 2014-06-11 07:40:03.442
HomeSet MultiSwitch Switch 1 is turned on true 2014-06-11 16:55:34.614 2014-06-11 16:19:19.408
LR_MotionTripped Living Room Motion armed is tripped false 0 2014-06-11 17:41:42.065
PR_MotionTripped Playroom Motion armed is tripped false 0 2014-06-11 17:41:22.801
RearDoorTripped Rear Door armed is tripped false 0 2014-06-11 16:55:34.486
So StaySet and VacationSet haven't been true since 16:55, yet I got alarms at 17:20 and 17:36. Could this be a serious delay in alerting?
