Hi
I have the AP003 working perfect with the exception it shows dropped, it however is not and still does what it needs to.
Name Wanscam IP Camera
device_type urn:schemas-upnp-org:device:DigitalSecurityCamera:2
altid MEYE-136453-CDDDA
ip XXX.XXX.XXX.XXX your ip
mac You Mac address for the camera
manufacturer Cellcom
model PTZ Camera
id_parent 0
device_file D_DigitalSecurityCamera2.xml
id Your system will create this
pnp Your system will create this
room Your system will create this
impl_file I_CellcomIPCamera.xml
time_created Syste, to generate
plugin 8261
category_num 6
key
device_json D_DigitalSecurityCamera2.json
poll 1465239152-1,1465239158-1,1465239164-1,1465239166-1,1465239170-1,1465239171-1,1465239176-1,1465239176-1,1465239181-1,1465239182-1,1465239187-1,1465239192-1,1465239247-1,1465239253-1,1465239259-1,1465239265-1,1465239271-1,1465239277-1,1465239294-1,1465239299-1,1465239304-1,1465239309-1,1465239390-1,1465239396-1,1465239413-1,1465239503-1,1465239508-1,1465239514-1,1465239521-1,1465239526-1,1465239531-1,1465239536-1,1465239542-1,1465258462-1,1465258467-1,1465258472-1,1465258477-1,1465258491-1,1465259519-1,1465259526-1,1465259532-1,1465260124-1,1465260141-1,1465260147-1,1465260152-1,1465260157-1,1465260162-1,1465260170-1,1465260175-1,1465260180-1
username Set to admin on camera
password Set to admin on camera
skip_view_emulation_popup 1
local_udn System will assign
This will assign everything on your other fields. Good luck.
